I am current in process of converting my empty basement into something more enjoyable. I have reached the point where I want to put up the walls of the bathroom. Before I can do this I need to put in the rough in plumbing connection for the bathroom. I have to cut the basement floor to get to the main sewer line to join the drain lines from the bathroom to the main sewer line. Once the floor is cut and I have access to the main sewer line I plan on inserting a necessary 3 way fitting into the main line. My problem is this, there will not be any play with the main line to get a 3-way fitting place and I need to use some type of coupling. What type of coupling? If I use the Fernco coupling can this be put into the ground and cemented over. And is there anything special that needs to be done to it before I do so. Or do I user a PVC repair coupling. However I read nothing but hoar stories when people have tried to use this with the glue drying to fast and not being able to get the coupling in place. That or they get it in place but it ends up leaking. Other people thoughts and experiences are welcome at this point.
