provlima
I have a 60 gallon State Select electric water heater that is 4 years old.
Recently it started putting out scalding hot water. I shut off the breakers and looked at the top and bottom thermostat and set both to the lowest temperature. It worked okay for two weeks,
but the scalding water problem started again. Has one or both of the thermostats gone bad?
Any other suggestions on what the problem may be? Thanks for you help
