Plott hound
short of buying a guzzler pump what is the best way to prime shallow well jet pump? i had to get mine rebuilt untill i can find a new one,i guess covid has caused a shortages of pumps.i hooked the rebuilt pump back up and poured water into the prime plug hole,then hit the power.pump runs and i get a few bubbles out of the prime hole but it wont pick up.tried 3-4 times letting the pump run about 10 minutes each time.is there anything around that i may use to draw water into the pump housing?
thanks
thanks
