neporcupine
I live on a 3 acre lot. This meter pit is on the far border from my house, so water lines run a ways to point of use. We are in nebraska, so we do get winter.
I want to put in a pressure reduction valve. The main inside house **** off does not shut off my yard hydrant, so they must branch in the yard somewhere. My pressures on the house spigots, and the yard hydrant run around 90-100 psi consistently.
The only way to have control of all pressures is to put the regulator on after the meter. How would you guys put this on? The meter pit is relatively narrow, and the meter itself is 1.5 foot underground, and the outflow pipe will naturally be a bit deeper. Getting to this would be quite awkward.
I know not to use sweat fittings on buried copper. This is not technically buried, but is outdoors. Thoughts? Thanks!
