KFreerksen
Hello,
I currently have a 40 gallon Power Vented Natural Gas Water Heater installed in my house. It is about 15 years old and is starting to go out. I would like to replace it but would like advice on what product to get. 2 years ago we replaced all the water lines with pex, and ran hot water to a manifold with a line from the manifold to each fixture. I can get an equivalent power vented water heater for $800 but I am also considering buying a tankless water heater for a similar price. I was looking at a Rinnai 9.8 gpm 199,000 btu tankless, but I have some concerns.
1) I only have 1 bathroom but our water here runs pretty cold, typically around 45-55 degrees so would need a considerable increase lowering the flow rate. Will we have issues triggering hot water due to low flow? I can't really rerun the lines again to accommodate a recirculating system.
2) Current WH is only 46,000 BTUs and has a 1/2" gas line. there is a 3/4" line ran to the area that splits to two 1/2" lines to supply the WH and Furnace. Will a 199,000 BTU tankless water heater need a new dedicated 3/4" line rant to it or can I use the existing line for both furnace and tankless water heater?
Any input from someone with more experience with tankless water heaters would be greatly appreciated.
