I'm a home owner, not a professional plumber.
20+ years ago, a water treatment company installed a calcite water treatment system in my basement with a Fleck timer and tank. They ran the purge line from the Fleck through flexible poly tubing 0.494" OD (what size is this?). They cut my kitchen sink drain line (2" Sch40 PVC) and added a tee, trap, and 10" open vertical pipe. They put the poly tubing into the top of the vertical pipe, making some kind of air gap, probably to prevent drawing waste water back to the calcite system.
For the past 20+ years, I've suffered with this system splashing large amounts of water out this air gap. When the calcite system purges, I get approx. 1 gallon of water on the basement floor, because the vertical pipe fills faster than it drains. When someone pours large amounts of water into the kitchen sink, I also get overflow.
A few years ago, a plumber increased the water pressure in my house by adjusting my well pump. That seems to have made things worse, probably because there is even more water coming out of the calcite system on its periodic back-flush.
I tried cleaning the 2" PVC drain pipe with a 25' long metal drain auger, in from the kitchen cleanout. That had no effect. So I don't think that the main PVC drain is badly clogged, although there could be some small buildup there. I've also emptied the trap from the bottom port, and it contained no blockage or solids.
My first thought is that the poly pipe should have had a closed system with a check valve rather than air gap and trap. But before I modify it, I'd really like some good advice.
I really welcome your suggestions. Thank you.
Bob
Bob
