Can anyone explain what may have caused the pipes above my water heater to become bent?
I attached a "before" photo from a couple years ago, that shows the water intake and outlet pipes from the water heater are both vertical.
I noticed today that the pipes are now both bent inwards towards each other, see "after" photo.
I'm not exactly sure if this was gradual or sudden, just noticed. I thought initially maybe the floor heaved, but there is no evidence of drywall cracking on the wall next to the water heater. Plus, the pipes above are PEX, so they should have enough flex to not deform the pipes below. I am thinking they must have been bent at the water heater itself.
The water heater has never given me any trouble; it is about 5 years old. I noticed the gas control box LED is flashing out a signal for "weak pilot signal"... not sure if that is relevant, or if it needs to be addressed.
Thanks for any suggestions! It seems weird, not sure if I should just ignore the pipes, or they are a sign of imminent failure.
