Hey folks. My wife and I bought our home in 2005, first house and were on a tight budget being only 25 y/o at the time. Since we have done a little remodeling here and there and this year have enough in savings to redo our master bath. We have battled pressure issues since we moved in but kinda of grew used to the low pressure. The issue is now with the remodel, we want to use a couple nicer shower heads in our shower and I know the pressure/volume will be an issue so its time to fix that.
Currently I have a well about 75ft deep. IIRC 3/4" or 1" coming in to the tank. Off the tank it is 3/4" for about 8ft up and then its 1/2" both hot and cold for main lines and its a tee fitting at every fixture. Our shower is the last on the 1/2 run upstairs. I want to run 3/4" as long as I can and up to the shower if possible. I figure using 3/4" pex main lines and using a tee to 1/2" at each fixture like now would be a great improvement in volume/pressure.
I want to upgrade using the pex material but had 2 questions about it.
1: I have read that utilizing a manifold system is good, problem is I only see 3/4" in and 1/2" out lines on all of them. Will I accomplish the higher pressure/volume I am after using this system over my proposed change over to 3/4" main lines with a tee at every fixture like I want.
2: I need to plumb into my furnace for the hot water, it is a hot water on demand system and the cold is plumbed into it, then out of it is the main hot water line for the house. How close can the pex be plumbed to the furnace with out a problem? I can use 3/4" copper if need be to do the furnace plumbing if I have to.
Thanks in advance for the assistance.
