Badhandyman
Hi. I'm replacing a pool pump which had 40mm fittings and the new one has 50mm fittings. I have installed 40 to 50mm connectors on each outlet but not glued yet. When running the pump the down pipe connection is leaking around the connection point and then pulls apart due to pressure. Question is do I need to silicon where the piping goes into the connector and also will gluing them together fix this issue? Thanks for any help. I was hesitant to glue it before I had it working.
