michaellloyd
Hi!
I want to remove a floor-based dehumidifier from my bathroom and replace it with a humidity-sensing ceiling fan vented outside. The dehumidifier has a reservoir with a 5/8 inch rubber hose connected to a 1 1/2 in horizontal waste line which attaches to a tee joint plumbed into an under-mount sink waste line in a cabinet. I want to cut and cap the pipe inside the cabinet for cosmetic reasons, between the hose connector and the elbow. Can I cut the pipe with a hacksaw? How would you recommend installing the cap - PVC cap cemented to the pipe or a screw-clamp jim cap?
What's your advice w/r/t odors/leaks etc.? Anything else I should think about?
