The white lines are supply lines. Why is constant height or distance be important once they are connected? Although I would support the right side better if it were me.
Even a 2x4 between the supply and drain with a few zip ties.
What you have there is an installation where pipe are supported by other pipes, which is a violation of most codes. A similar product already exists and is not to be used in my area.
Not much good for sinks that are arms. Which most kitchens are because of a window above. Lavs also with builtin medicine cabinets above the sink.
You're right, however we've only had one inspector not allow it, and have made an effort to get it in front of as many inspectors as possible. Including the board in our area.
Do you remember what the similar product you've seen is called?
IMO the code is a little outdated.
How do they fasten it to a horizontal line? Do you not know what a waste arm is?
I don't remember what it is called, but all of the supply houses carry them. Of course they can sell something even though it's not approved by local codes.
I don't believe the code is outdated in this circumstance and I'll explain a few reasons why.
When a pipe supports another pipe, the supporting pipe can be stressed. When servicing, repairing or adding on to an existing pipe a plumber may have no idea what concealed pipe-to-pipe supports are in play and could do damage to good pipes or he could even get hurt by falling pipes. If an exception is made for lavs/pedistals, then where does the line get drawn for larger and heavier pipes where the above situations could be magnified?
I have been the victim of pipe-supporting-pipe installations and see it as an unnecessary shortcut to lessen the quality of the job.
metal, not plastic
