Is it possible to use PEX-AL-PEX with freon in a refrigerant system?
go steveie go stevie go stevie !!!!!!I got a bit curious myself and it seems that you can use PAP for refrigerant purposes. PEX-AL-PEX Pipe and Fitting Systems: PEX-AL-PEX pipe and fittings used in used in refrigeration applications shall have a working temperature range of -40 to 250°F (-40 to 121°C), a maximum design working pressure of at least 840 psi.
That's according to http://www.icc-es-pmg.org/Criteria/Approved/PDF/LC1035.pdf
Also I found this http://www.canarsee.com/differences-between-oxygen-barrier-and-non-barrier-pex-tubing
They give a pretty good chart of what uses are compatible with which types of PEX, which in your case is clearly listed about your Freon situation.
So to answer your question, Yes you can use PEX-AL-PEX with Freon.
