Recently I purchased a new house. The previous owner had installed two 40 gallon water heaters and hooked them in parallel. The two tanks are identical in make/model except one is brand new and one is 4 years old. Here is my problem, despite the piping appearing to be identical to both tanks, one tank is doing the vast majority of the work. The new tank is probably supplying 80-90% of the hot water and I can't determine why. Obviously this undermines the purpose of having the two tanks. Is there a way I can fix this? Here are some ideas I have had.
1) Could I minimize the water flow from the newer tank by regulating the hot water outlet with a valve and hope that this starts to draw more water from the older tank? As in partially close the valve. (this may be a stupid idea but maybe not?)
2) Remove the parallel setup and install the heaters in series. This is less desirable but if I can't equalize the flow I will have to
If anyone knows how to deal with this do let me know. Thanks
