One piece flush valve unscrew?
Jhonny3
Aug 16, 2023
Ohio
Anyone know how to remove this flush valve? I have a one-piece toilet in the house I just bought, can’t find the brand name anywhere, and this valve is leaking. I can’t figure out how to remove it. No screws I can see. Do I need a special tool? I am thinking maybe the tabs in the bottom can be turned? Anyone know a part to replace it? Thanks in advance!
Yes, turn the tabs counterclockwise. You can make a wrench to engage all 4 tabs with a piece of 1.5” pvc, cut four notches in the end of a piece about 2 feet long and use it as a wrench.
Replace with this one. You may need to cut the overflow tube to match your existing one.
https://www.amazon.com/Proposed-Attribute-1-piece-premium-flapper/dp/B00FL10S82
All that said, I’d recommend replacing that toilet. Trust me.
