I'm in the midst of setting up a temporary kitchen and want to make use of the slop sink found in the basement. The sink is made of heavy Earthenware or similar, about 1.25" thick. This may evolve into a permanent install and I'm having trouble finding a wall-mounted faucet with a 11-3/8" center-to-center spacing.
Single faucets (unmixed) would be the easiest solution, but wanted to see if modifying a dual-wall mounted faucet is worth the headache for the aesthetics, or if you had any ideas.
Here is a poor photo. You can see that the previous owner simply used hose bibs as faucets.
