Mike b
Old Delta single handle shower valve not getting very much hot water I changed the 2 rubber gaskets and springs and that didn't help thanks mike
use the wet vac on the holesI had my wife hold a bucket over the holes and turned the water on momentarily that should have cleaned out the 2 holes but still very little hot water any other ideas?
I will try that too thanksYou might also try using compressed air to dislodge any debris that might me in the hot water line.
Yay that vacuum and air compressor did the job . Thanks for the helpI will try that too thanks
