foxsprings
Hi all, first time poster.
I have a large water tank that I need to hook in to for both general potable water, and for fire suppression.
For fire suppression, it has a 4" female NPT outlet. I need to reduce this to 2 1/2" male NPT and install a gate valve. I am looking for a supplier for the reducer bushing, and the valve. I would prefer brass, but struggling so much that I'll take whatever I can get.
For the potable water aspect, I have 2" female NPT ports for both the inlet and outlet. Clearly for a domestic supply I do not need 2" pipe, so I'm happy to reduce that down.
However to make it more complicated, I need to be able to pass the pipe THROUGH the port, not just have connected to the outside.
The reason being that the inlet needs to have a float valve inside the tank (with a calmed inlet), and the outlet needs to have a floating pickup inside the tank.
I cannot find a fitting that will thread on to the port, but allow the pipe to pass cleanly through. I spent some time trying things like 1 1/2" PVC inside 2" PVC etc, but cannot find anything that fits tight enough.
Can anyone help me with the correct terms for these kinds of fittings, or a supplier I try?
This image describes the non fire aspect well.
Many thanks
Many thanks
