So, the black pipe in the back is open at the top with the dishwasher drain hose stuffed in it- this has caused a huge leak recently when it fell out. I was looking online and stumbled across a "fix" for the previous persons improper plumbing job http://amzn.to/1TWTuJ2
So- a couple questions...
1. To properly install this it should be directly under the sink drain above the p-trap (currently the white pipe) correct?
2. Why is that black pipe even there (the one in the back)? Can I just cap it off at the lower joint and if so with what?
3. I'd like to affix the drain hose and fill hoses to the back of the cabinet to make room in the cabinet- is this advised and if so what is the necessary clamp called?
Thanks!
Thanks!
