Over the summer my hot water heater started leaking water out of the Temperature/Pressure Relief Valve (PRV). About 10 days ago, I changed out the water heater and installed a new energy efficient gas water heater (whirlpool model number ND50T122-403). Installed it fairly easily with just some minor retrofitting for the venting as this unit was a few inches higher that the original. Come to find out the actual culprit of the leaking was the expansion tank (2 gallon). The bladder had failed. I bought a new 2 gallon expansion tank from Lowes (Utilitech model LET-2). I also installed new fittings coming out of the wall as the gate valve was old and slightly leaking. I replaced it with a ball valve. I thought I had the problem figured out. I was still leaking water out of the PRV (over 5 gallons a day!) I bought a pressure gauge and checked my home water pressure which was right around 100 psi! I went to the street and adjusted it down to 50 PSI. I matched the PSI on the expansion tank to match. I'll be damned if it is still leaking! water temperature inside the house is 122 degrees. (seems perfectly normal). There must be some simple procedure that I am not following. I am going crazy.
Hot water temp: 122
Street water pressure: 50PSI
Expansion Tank pressure: 50PSI
http://pdf.lowes.com/installationguides/091194008415_install.pdf (expansion tank)
http://pdf.lowes.com/installationguides/035505146700_install.pdf (water
heater)
Thought I had it fixed again. Went 16 hours yesterday without a drop of water coming out of the PRV. The water heater came on a few times yesterday to heat water and nothing came out! Went to sleep and woke up to a full bucket (5 gallons) of water or more (overflowing) out of the PRV. That seems like a large amount of water being relieved out of the PRV. what am I missing???
Thanks for your help.
Hot water temp: 122
heater)
