New shop bathroom.
Chris
Jan 5, 2010
8,850
948
Sweet, Idaho
Hi Guys, as some of you know I bought a place in Idaho that has a shop on the property. I just took possession of this house last week and notice that the shop is plumbed for a bathroom. I don't know much about plumbing but was wondering what info you guys could give me on how it was run and what each pipe was probably going to be used for? The old owner didn't give much info and thinks it has it's own septic so I will have to do some digging to see if that is true.
I THINK the last picture is a toilet, with a vent behind it. Second picture from the bottom is probably for a shower, with a vent. Third from bottom is a floor drain. 4th from bottom is a floor cleanout. The pipe to the far left and front of the other picture is probably for the lavatory.
15 acres, backs to BLM land on one side and a couple thousand acre cattle ranch on the other. Has two neighbors and across the street from the Payette River and a mile from Black Canyon Reservoir.
I put a urinal in my house, $100.00
the flush valves are $300.00 and more
so i used a spring return valve, $50.00
you turn it with your hand, let go, it spits a little water and shuts off
works great for me
I need to set it up like a home bathroom because if I turn the upstairs into an apartment or guest place it makes the best sense, I guess I should start with seeing where the drain goes outside.
