put new bathroom in - water lines, drain lines, tub, sink, toilet, and washer - with all new plastic drains. the sink and tub (on same side) drain very slowly. the tub drain is no further from the pipe going down the wall than the washer (both maybe 9-10 feet so not much of an angle on the pipes). the sink and the toilet are closest, and on each side of the down drain. the tub always has a few inches of water when using the shower and the sink backs up when water is run on medium. every once in a while there is a bubble in the sink (like a burp?). the tub and sink are on one side and the toilet and washer are on the other.
also the first person who takes a shower always gets a cold shower. it heats up slowly. it's on the second floor. didn't have this problem with old shower. the water is very hot and needs turned down with next shower.
