need to remove pvc spigot from pool deck
michaelaj99
May 15, 2016
In the middle of our pool deck stood the water slide and when the slide broke we tossed it. Now we have a PVC water spigot sticking up in the middle of the concrete. Is there a way to cap it, (Water still flows) without tearing up all the concrete? Maybe grind it down below concrete level and plug it securely with something?thanks [email protected]
Can you cut the PVC line where it enters the concrete, away from the deck? This way, you could just cut the PVC below ground, then fill the hole with a concrete epoxy.
