I need advice on a annoying power steering leak on a 2001 Suntracker Regency pontoon boat. This leak was bad enough that it ruined my stereo from the drips of power steering fluid.
As you can see on the attached picture, it appears the leak is coming from elbow fitting at the top of the housing. I mentioned to a boat shop owner that I was going to wrap the threads with Teflon tape, and see if the leak stops. He told me that Teflon tape will become absorbed in the system, causing me to replace the entire $700 unit. He recommended to use only the white liquid pipe sealant, and I replied that Rectorseal #5 would probably work the best. He then said that will also not work, but could not advise the actual name of the white pipe sealant.
Does anyone have any ideas on what this mechanic is talking about?
