greenhaven
Before I post my first question here, let me say that I DID scour the Water Heater section looking for an answer to my issue, but no luck.
While in the process of draining my old 40 gal gas WH yesterday, I noticed that even though it was draining just fine, something wasn't right. I had the water supply ball valve closed, but the tank would not empty. I closed the Main at the curb and the WH emptied within 45 min. I assumed the ball valve was bad, so I replaced it. I left the new ball valve in the closed position and went back out to turn the water back on at the Main. Upon returning to the WH, I could hear it filling up. WTF? I double checked the ball valve and it was closed. I again turned off the water at the Main. I then attached a water pressure gauge to the hot water side pipe going into the house and turned the water back on. The gauge read 65 psi. I removed it and then attached it to the supply side and opened the ball valve. It also read 65psi on that side.
I'm puzzled and wondering why I have water pressure coming to the WH from the hot water side. Has anyone experienced this before? My new WH won't be here for another week, so I've got a few days to figure this out. Any thoughts would be appreciated. Thank you.
