Tumbleweed
Good day. I have this threaded connection that still leaks. This is a John Guest MPT plastic adapter threaded into a stainless steel street elbow attached to a sediment filter. First I tried using the standard (white 1/2" wide) PTFE. Water droplets formed under the lip at the female end of the street elbow. Leads me to believe the water is tracking the stainless steel thread. The local plumbing house suggested I use a Gray PTFE for Stainless Steel fittings, as it was thicker. With the Gray tape, the water now appears at the start point of the tape wind, as if the water is tracking the adapter's threads under the tape. My winds are always clockwise starting higher on the thread, overlapping by 50%, and working towards the end. I am leaving the last thread bare to make it easy to start the thread into the female end of the street elbow. I have tried 2-layer wraps and 3-layer wraps and have not found a remediation to the slow drip. Slow drip being droplets appearing about every 90 seconds.
Before I discard the John Guest adapter and solder up a length of 1" dia. copper to a MPT Adapter as a substitute, I wanted to get feedback in case there is something I am missing ? All feedback, responses, and recommendations are welcomed. Thank you in advance, David.
