Guys, I have a tankless gas water heater and the main hot water line is 3/4" PEX about 70 ft long. I'm wanting to put in a recirc line. I'm going to use a small electric water heater to keep from having a cold sandwich effect.
So basically, I will have hot water come from the tankless heater and go into a small electric heater. The water will then go through the main line and circle back to a pump (Grundfos UP10). From the pump the water will go back the the hot water line between the tankless and electric water heater.
I got this idea from a Rinnai PDF here Mash
As you can see in the PDF, it has an expansion tank between the electric heater and the fixtures. What size expansion tank do you guys recommend? What size electric water heater do you recommend?
Thanks! Oh and I've already checked with my tankless manufacturer and my tankless WH was designed to run in this type of recirc setup.
