I have started renovations on a master bathroom and have been contemplating fixing / replacing the drains for this bathroom. Bathroom has been gutted to studs and subfloor. House is from the late 50's or 60's. Located in Maryland. Here's my reasons for looking into this:
- Shower drain is not high enough for new shower base (will be traditional mortar, liner, mortar, tile shower pan)
- Would like to move shower drain a few inches to center it in new shower (old shower stall was smaller, new design puts drain close to one end)
- Toilet flange is beat up from floor demo (my mistake) and soldered to 3" copper pipe. May need height adjustment for new floor so replacement is ideal.
My concern is the layout of the existing drain system. It is not a continuous vertical stack. From the roof near center of house, vent pipe comes down in wall with kitchen on one side and guest bath on the other. Kitchen sink and guest bath sink connect to this pipe in the wall.
Once the pipe enters the basement, it makes a horizontal turn and heads towards the side of the house, perpendicular to the floor. The toilet for guest bath is attached with a wye just after the horizontal turn.
Next is a left turn towards main drain pipe. Along the way, the master bath shower drain, guest bath tub drain, master bath toilet and master bath sink all connect with straight, vertical tee connections. I suspect this was done because the guest bath and master bath share an interior wall and running everything inline was easier / cheaper? Is this even up to code anymore?
From there, the line makes a right turn, heads back to the foundation and into a main drain pipe. All of this is copper and brass with what I assume is a cast iron drain pipe.
No idea what to do, no idea if the existing configuration is up to code or allowed. I was thinking of just cutting the copper off for the master bath drains (branches), then replace with PVC.
Then I thought why not cut all the copper out between the main drain and guest toilet and replace with PVC as a preventative measure; but that would leave the vertical pipe and (newly finished) kitchen and guest bath with copper drain pipe. Is that ok?
We will likely be here for at least a few years so my dilemma is do I redo as much as I can now and consider it preventative maintenance? Or do I just do what I need to get the bathroom finished and functional / safe and just assume drain system may need more work or to be redone when it comes time for sale / inspection?
Any guidance would be appreciated!
