Hi, I need to replace my 1/4 turn valve and pressure regulator because you can see from the pic its about to blow! The pressure at the outside faucet is 130 PSI which tells me the pressure regular is not working.
A few questions I have
I bought a double union pressure regulator, then 2 threaded 3/4 copper to slip joint for each end of the pressure regulator. What type of 1/4 turn ball valve should I get? I see there is double threaded, thread to slip joint.. I have read you need to be cautious sweating copper around the ball joint.
Should I use threaded? My concerns is too many threaded joints. I need a picture of a proper job.
http://sdrv.ms/1bfRccP
