Need enlightenment...or is it a paranormal phenomena?
piew
Nov 17, 2014
Hi, I'm new here and humbly asking for masters here for enlightenment.
My friend had just got his apartment, and he re-do the piping in the bathroom.
After about a month or so, he found that the water flow rate is going much lower than before, out of sudden. Not even enough to activate his water heater.
The water tank if full, the main valve is good, the pipes are new...He don't know what to do, I lend him a water pump and did a silly reverse flow from one of the taps to flush the water up back to the water tank.
It works, the water resumed it's flow rate and everything was good for the next few days before it happened again.
This time my friend himself went up to the ceiling, insert a flexible pipe into the water outlet inside the water tank, and blow with his mouth several times, with all the water taps switched off. Yea, this is dumb but it works!
I thought at the first time I might have flushed out some object that stuck in the pipe back into the water tank. And the object went back in so it happened again the second time.
But....this is beyond my understanding now. The water resumed high flow rate by blowing air into the outlet pipe, with the taps off.
Anyone can explain this? Please~~~~
:confused:
:confused:
I surely don't know much about water systems in Klang, Malaysia. Can you enlighten us before attempting to answer you?
