Need a water softener
Otahyoni
Jan 5, 2010
1,780
13
Terre Haute, Indiana
Ok guys, need some recommendations for a water softener. Our water hardness is about 15-20ppm. We have Lowes and Menards locally.
I checked at Menards and all they carry in the store are Waterboss (poor reviews on amazon) and Morton system saver.
At Lowes the 30k grain Whirlpool model has very good reviews.
I'm not really sure how large of one i need. We have 1 bath and only 2 people living here.
I'd like to not spend much, but i realize this could get expensive... :(
Can we try to stay under $600 though?
Although the water here is extremely hard, I don't want to deal with another machine needing maintenance, needing fixing or adding salt. For a few years I had the tank which was replaced monthly, but at $50 per month, I'll tough it out without one!
It killed our dishwasher.... I thought it would be best to get a water softener before replacing it.
Might help sell the house too... and currently i'm not getting any dishes cleaned... :(
Was the dishwasher working at one time or another? Maybe the element on the dishwasher is broken....I've dealt with a few of them before.
The heating element has an 1/8" layer of scale on it, and it wont clean the dishes any more... tried a few things to clean it but nothing has helped... :(
And it's not the only thing with scale built up... shower head, couple faucets... And i'd hate to see what our pipes look like... :eek:
Put a quart of white vinegar and run a few cycles in your dishwasher. it will clean up the scale quickly. If you are set on a water softener, just keep an eye on the reviews or heed the advice on some of the experts here who could tell you more.
A friend of mine sells and installs the occasional softener, so while I wouldn't necessarily call him an expert, he knows more than I do about them.
He tells me to NOT buy anything from Lowe's or the like, with electronic controls. Once those start to malfunction, how do you troubleshoot or repair them? My mother has a model that is all mechanical, and in 15 minutes over the phone, my buddy talked me through a diagnostic check that solved the problem.
I'd imagine those are far and few and expensive...
My parents have an electronically controlled one that is 15+ years old...
How true! Stick with one built by a local company with either a Fleck or Autotrol head. People in your area will work on them and they are readily available as are their parts. The others are not and you will pay dearly for repair on that proprietary equipment. If you can find anyone to repair them.
My normal 1 cu ft unit with a fleck metered head goes for $750.00. I haven't shopped the big box stores, but I don't think they are much less and theirs are not quality.
Am I the only one or is everyone completely disregarding a basic piece of information here. 15-20ppm hardness and you are recommending a softener? At any price?
Since 17.1ppm equals ONE grain per gallon, I would hardely suggest wasting money on a softener.
Now unless the OP's original number were meant to be gpg, then he should have been asked many other questions before recommending any piece of equipment. How much iron? TDS? Number of people? etc.
Andy Christensen
I agree, if it is ppm. I missed that when reading his original post. I guess I assumed gpg.
Problem with the big box stores is that most people go there and just buy what's on the floor. Never having their water tested prior to installing whatever.
Thanks for the link, speedbump.
Quick reference for hardness tests:
very soft <17 ppm = 0-1 gpg
slightly hard 17-51ppm = 1-3 gpg
moderately hard 51-120 ppm = 3-7 gpg
hard 120-256 ppm = 7-15 gpg
very hard 256-425 ppm = 15-25 gpg
are ya kiddin' me? >425 ppm = >25gpg
Today is another one of those days where I learned something new.
Lucky me, I had a well at my previous house that had 42 grain hard water. It hurt to take a shower. Rather than buying stock in the Morton Salt Division, I relocated and drilled another well. By moving about 250', the hardness went down to 17 grains. That one was much easier to deal with.
My pool is constantly 500 PPM. every time I get the water tested, they recommend to drain off 1/2 the pool (~15,000 gallons for 1/2 the water) and refill it. With my water bill ~$150 a month already, I'll leave the hard water. It's also fun to be able to walk on water! :)
I wonder how it got so hard in the first place.
I can't remember ever checking mine for hardness. I guess that might be the same as alkalinity.
They say is is leached from the 2 year old plaster, but I don't believe them. I did drain 1/2 the pool and refilled it once and the PPM was reduced to ~450. Not worth all the money IMHO! If I had a back hoe, I'm fill that pig and plant a garden!
Thanks for pointing that out....I used the wrong unit of measure.
According to the test strip its a little over 15 grains per gallon...(~250ppm)
I'm trying the vinegar solution in the dishwasher, and it that gets it to cleaning dishes I'll probably forget the whole thing....seeing as how i plan to move within a couple years...
Either way, i have to have a working dishwasher if i want to eat... bosses orders... :D
