Scotsman62
We have a 7 year old Navien NPE-240A (NG) that has had regular maintenance such as cleaning of filters and descaling annually. We did have issue back in early summer when it went down, (no power) fuse was blown and having the fuse replaced didn't correct the issue. Plumbing and heating contractor contacted Navien tech support, advised to replace the circulation pump and control board, when that didn't fix the issue then Navien tech support advised to replace ignitor and flame rod, finally that solved the issue. New issue is an occasional "backfire" (it took me a while to figure out where the noise originated) Unit still working and no codes. OK, so the closest Navien Service Specialist is 100 miles away, Navien will only talk with contractor, any Navien experts with any thoughts as to what our problem is would be appreciated. Cheers!
