Thechevyman122
Howdy, I recently moved a gas line (1/2" black pipe line) it was a minor thing, Had to go back maybe 4 joints then tightened back to my furnace.
Long story, I soap checked everything and everything is good but I wanted to leak check. So I turned off the three valves to gas appliances I have (water heater, furnace, and range) and marked my meter. Looks like I am "losing" about 4/5ths of a cubic ft an hour.
Now I know this isn't a standard pressure check, and I ordered the gauge to actually pressure check my line per code, I also didn't do this test before hand so it's possible nothing has changed.
Just curious if any of you mathematical/plumbing people can answer if that's a dangerous amount? I tried to convert to weight and it seems like a minuscule amount, but my conversion could definitely be wrong. No smells of gas, but my gas lines are under my house and I understand gas is heavier than air so it would "settle".
