What is the best way to vent the fixtures in a multi-story apartment building which has single bathroom groups stacked on each floor but no plumbing chase.
The fixtures back up to a 6" stud wall. The building is under the 2009 IPC.
Can you use wet venting for each individual bathroom and tie one fixture from each group into a relief vent going from the base of the stack to up to the top?
Also can you tie a furnace room floor drain into a bathroom group or does that dis-allow it from being wet vented?
Thanks
Chazz
Thanks
Chazz
