daniel600x
So, I my townhome, my main bathroom sink is located between two walls. The plumbing to the sink comes out of the left side of the vanity. I purchased a new 60" vanity with sink in the middle and drawers on the left and the right side of the sink. My goal is to move the water pipes and the drain pipe from the left wall through the 2x6 inside the common wall to the back of the vanity which is the standard now. I don't wanna lose any of the left drawers if I had to run the plumbing pipes from left side through the drawers allaway to the sink in the middle. Can this be done? Can water lines (I ma thinking to run PEX ) be run inside the common wall? Should I use Sharkbite tee to connect to the existing water lines? I never soldered copper. Please help
