Hi.
Please see this diagram of my current setup and what I plan to do. Any comments welcome.
https://www.dropbox.com/s/xk8sdp0mgzsmyfi/Furnace Room Drain.pdf?dl=0
I have a bar sink in my basement, and it is connected by 1.5" PVC to a 2" drain pipe in the floor inside the adjacent heating/A/C indoor unit room. Note: The drain line is adapted to the 2" drain and the whole connection is sealed at the drain; no exposed water. It also vents out through a stack in the same room. The bar is on the outside of the wall of the A/C room, which is located in the center of the basement. Just above where the drain pipe goes into the floor, is a J trap for the A/C condensate drain tube. The current location is in the way of other stuff (fridge, HW heater, etc.) and makes access to the indoor units a bit difficult.
I want to move the J-trap away from its current inconvenient location, and put it on the wall behind the sink, closer to where the condensate pump is.
Please see diagram here.
Do you see any problems with what I am going to do?
Thanks!
Thanks!
