I can’t help you then if the kitchen is getting hot water but the bathtub and lavatory are not and you only have one water heater...It's both sink and shower faucets.
Maybe they were using it as a tempering valve
It appears that someone years ago put a cheap gas valve into one of my water pipes for whatever reason. Everything worked fine and my bathroom water was hot until I took the leaking gas valve out and replaced it with a fitting instead. Now it appears I'm not getting enough hot water through the fitting and both faucets in the bathroom only get lukewarm.
I put two plugs in as Twowaxhack recommended and everything is back to normal. Thank you for assisting this extremely amateur plumber. I very much appreciate it.
