mngreenguy
The previous owner moved the furnace and water heater and put a bathroom where mechanicals used to be. The only issue is he didn't plumb a drain, the solution was to run a garden hose through the wall into the shower which rotted and started to leak.
My ideas
1. Install a condensate pump, run pvc up through the ceiling and through the joists to the utility sink in the laundry room. Down side is the basement is finished an i would have to cut into the ceiling and through 12 joists.
2.Run pvc back through the wall where the garden hose was and tie into the sink drain rather than the shower. (i'm not sure if tying into the sink drain is possible.)
3. Run pvc back through the wall where the garden hose ran and dump into the shower. Downside is the water stains the tile and is ugly to look at.
Thanks for you help Nick.
My ideas
