Keith Welch
- Joined
- Jan 9, 2025
- Messages
- 1
- Reaction score
- 0
Hi all, newb here. I have a long story about issues with my main drain line. Background: 50 year old house, cast iron drains. All drain lines lie under a slab. Main line goes to a sump. Sump is pumped to municipal sewer at street level. I have two issues. One is that I probably need to install a lining on the main line (about 75’) due to general loss of integrity. That is more of a chronic issue. Second issue is more acute. About 5’ upstream of the sump, there is a buildup of some sort of mineral deposit (my current theory is that it is from years of deposits from washing machine discharge). This buildup creates a little inconsistency that causes clogs to form periodically. Every 3-6 months or so I have to go in to the sump and send a snake up into the line to clear it out. I’m now 65 years old and pretty much done with this routine. I want to solve the problem once and for all. I fear that the only solution is to excavate this portion of the line. I tried to send a chain buster into the line to break up these deposits. But on top of everything else, there is a 90° elbow, just before where the line connects to the sump. So, maneuvering a snake with a chain buster on it up into that area is like wrestling with an alligator (working from inside a drain sump back up into the main line). It just won’t work. At least with the equipment that I have tried. I have run a camera up into this space and I tried to upload a video but it’s too large. I have a plumber scheduled to come do a video inspdction ($$$$) because they won’t accept my video, of course.
I’m looking for thoughtful input on any possible DIY solutions to this problem. I do have a clean out located just about where this anomaly is. But even that clean out is not easily accessible, and even if I can bust out this mess from there, there may be more of it upstream of the cleanout. I have a feeling that I am going to be excavating a portion of my garage floor and digging out the last 10 feet or so of my main line.
Thanks for any ideas.
