Starcraft27
When digging in the garden one of the 3" Corrugated solid drain pipes that runs from a rain water spout away from the house was hit. I thought this would be an easy repair with a coupler and new pipe. After digging up around the pipe I noticed it was T'd with another spout which wasn't a problem. I decided the best way to fix was to put new pipe from the T and couple where the pipe was in good condition.
I got the same 3" pipe and a coupler and proceeded to fix the problem. I correctly coupled the repair and rain water through it to test. It is leaking at the coupler I repaired and at the T on both sides where the water runs. Is there a type of sealant or Duct tape I can use to stop these leaks? I'm not talking a drip but a steady stream where a lot is being lost before it drains at the bottom of the driveway where it should. I tried zip ties and was even considering silicone sealant.
