hammerlane
Had an Oatey single handle washing machine valve that was about 14 years old. Developed a leak at the handle. See photos.
I was able to take old valve off the taps but could not figure out how to remove valve stem from valve body to replace any bad o-rings or seals.
Anyway I ended up putting on a new valve body on the old taps and afterwards looking at old valve body more closely was able to figure out how to remove valve stem to access o-rings. It was a rubiks cube. See photos in case you have similar problem.
