Leaking from the ceiling
karmacheema
Dec 6, 2013
Ok so we got our first freeze and of course the hose was left on the spigot outside and it froze causing the pipe to it to burst I cut and capped it till I Actualy need water outside again but when I turned the water back on the ceiling in my basement started to leak I cut into it to find the problem but no more pipes burst where it's leaking where the copper pipes connect to the ceiling/upstairs floor has a leak coming out of it. it's a white connection where the pipes are inserted any idea what exactly is causing this? I'll add pictures shortly
If you are talking about the ribbed plastic part where the copper penetrates the floor, that appears to be nothing more than a plastic pipe strap holding the pipes in place. If there is water leaking through those, then the leak is above the floor somewhere.
I really appreciate the info guises I should have updated but the following morning I chased the leak to a sink up stairs cut the pipe and used a sharkbite to seal the damaged area but now my bathtub in the same bathroom has no water coming out of it abs there's no leak as of yet to suggest a burst pipe
