neverknows
Situation:
Main floor with Daylight basement. Main floor has two bathrooms, basement has one. Regardless of which shower I use (main or basement) after I take a shower I hear a leak – drip, drip, drip, coming between the basement ceiling and main flooring. The only items that are in this area is a line that connects to the master water line and goes to an outside faucet – and one other line that T’s into it, that ‘may’ go to the downstairs basement bathroom, but not positive – and from what I recall the T line wasn’t in the area I hear the leak from.
The ONLY time I hear this is AFTER taking a shower – which to a layperson such as me does NOT make sense, because water would always be in any pipe – and I only hear it after a shower. Can a leak sometimes only occur after some type of a pressure change – and otherwise not leak??? I’m truly stumped by this…..
Here were my thoughts:
1. Master bath shower floor (tile) was having issues, or leak at showerhead behind tile – but again, occurs in any of the showers – so it doesn’t make sense either.
2. Doesn’t occur if you just use sinks, toilets, etc. – only after a shower.
This is driving me to drink more…..please let me know what it might me, things to try, etc.!
Thank you all for reading and hopefully providing an answer!
David
David
