Installed a shallow well pump ( sprinkler ) that has threaded inlet and outlet . After gluing all the pvc pipe together ( after screwing in the threaded inlet and outlet) I discovered a small leak at the outlet side coming from the threaded adapter. Since it's now all glued in place I can't tighten the adapter since it would twist the pipes. Any suggestions on how to stop the leak ? I used plenty of plumbers tape when I threaded the adapters onto the pump and tightened them sufficiently. Any help greatly appreciated .
