Is that literally just carefully prying the sink up and then resealing it when finished?easiest way is to disconnect the water and drain. pull the sink from the hole.
if nut will not budge, cut the nut in half
That doesn't sound too terrible. Thanks for the advice!yes, use a sharp knife. cut the caulk around the sink. pull it up. then clean all the old caulk off, recaulk the sink when finished
literally, cut the caulk, all the way around. pull the sink
when you recaulk....use dap , and a sponge. apply dap, wipe with a damp sponge, rinse sponge
recaulk as necessarry. wipe with clean damp sponge
repeat. till a nice bead all the way around sink
caulk, wet wipe,rinse, caulk, wet wipe,rinse, caulk etc
