Knocking Pipes
ScubaAg
Oct 15, 2016
I have an upstairs shower that creates a slight knocking sound when the shower faucet turns off. Furthermore, I notice this same knocking sound with the same pipe to the shower when I turn on the sink faucet that is three feet away. I was curious if anyone has any ideas before I resort to a local plumber.
I am not sure if this helps with a possible diagnosis and fix, but here is a little history to that shower. A few weeks ago I noticed the shower faucet had a slight leak. I decided to replace the cartridge for the shower faucet. I made the mistake of not turning of the main water supply. I idiotically turned off the incorrect valve. I quickly realized my mistake after getting a nice spray of water when I began removing the cartridge. Anyways, I located the correct main water valve and turned off the correct valve. I was able to correctly replace the cartridge and get rid of the leaky faucet. The faucet works correctly now.
It was not until a few days later that we began to hear this knocking sound. I figured it was a result of my idiotic mistake. My guess was I inadvertently loosened the pipe from a fitting or created a "water hammer". I went through the process of turning off the main water supply and running all faucets till they were dry. Then, I turned the water supply back on and tested the faucets. I did this process twice. Unfortunately, this same pipe still has the slight knocking sound. My only guess is it may be a loose pipe. Unfortunately, the pipe is enclosed in the wall and almost impossible to diagnosis without ripping out the wall.
Again, I hear a slight knocking when I turn off this shower faucet and turn on the sink faucet nearby. Otherwise, I do not hear this knocking in any other part of the house. I am not too worried about the immediate future with this pipe. However, I am concerned this knocking could create more serious issues down the road. I would rather fix this minor issue instead of a major issue at a later date. I am open to any suggestions before I turn to my local plumber. I appreciate any insight you may be able to provide me. Thanks for your time.
most knocking on a 2 story home, at the shower, is the pipe as it comes up thru the floor.
the pipe jumps when the water is first turned on, causint it to slap the edge of the hole.
go to home depoot, buy a 6x12 register, cut a hole in the sheet rock
below the valve close to the floor. not in the bathroom, bother side of the valve wall.
peg the pipes thru floor, install register, or patch sheet rock
images
