I've seen this problem posted a lot around the internet but none of the threads ever seem to include the resolution.
We have a single kitchen sink with a garbage disposal. The sink does not drain; if we fill it, it will sit there for days without going down. Turning on the garbage disposal makes it drain immediately. The sink also fills when we run the dishwasher.
The disposal itself doesn't seem to be clogged; if I disconnect the disposal from the trap, water runs through the sink and straight out the disposal with no problem.
If there's a clog somewhere in the pipe, I'm not sure why running the disposal would make it drain, and also I would think it would have become completely stopped up by now -- we've had this problem for a long time now (never got around to taking care of it until now). At any rate, I snaked it 15-20' or so and got nothing.
Is it a venting issue of some sort? What other troubleshooting can I try? If I have to call someone, should I start with a rooter or go straight to a plumber?
Here is a pic of the setup:
Seems weird to me that the pipe into the wall is several inches higher than the pipe out of the disposal, is that a factor?
