8/3/15
The house I moved into has the setup below (at the tinypic url at the bottom of this post) under the sink.
I have noticed that it is nearly impossible to get the garbage disposal side to drain properly and I am thinking it has to do with the 2 traps that are installed.
From my research (youtube videos and forums) it appears that 2 traps is a no-no in almost all cases. Additionally, I came across some information about venting, but I am unsure if my setup has, or requires, a vent. (there is a pipe running from the wall that has a black cover on it, but this does not appear to be a vent...maybe it was intended to be a vent, but it was never properly finished...or maybe someone thought they knew what they were doing and removed the vent there?).
I *think* what I need to do is:
1. Eliminate the trap connected to the disposal.
2. Run the disposal drain over to a new 'T' that would go below the tail-piece from the left sink (between the tail piece and the trap).
3. Run a new pipe from the single trap to the drain in the wall.
4. *maybe* replace the black cover with a vent?
Any help would be greatly appreciated!
[tinypic.com]
[tinypic.com]
