benjamin_wooten
Hi everybody! I am in a bit of a self-made pickle, created by my own lack-of-planning. I am hoping some of you might be able to help me out...
We've been remodeling our home for over a year now, and I am just about to put the new kitchen sink in. The original sink was a two bowl affair, as is its replacement. We removed the first sink very early on in the project. I meant to take pictures of the plumbing situation in the original sink cabinet, but apparently forgot (or, at best, can no longer find the pictures on my computer).
What I am facing is shown in the attached photo. The water lines make sense, but what confuses me are the two separate 2 1/2" pipes going into the slab.
I remember cutting and capping both of those pipes when tearing out the old kitchen. I thought, however, that the two-bowl sink had its drains joined with a y-connector, and that they went down a single drain.
The two separate pipes suggest otherwise?
I am in NS, Canada. I am not certain exactly how code compliant the house was when it was built (it did have permits pulled with the city, so it must have passed some level of inspection) but would it be common practice to have each drain from a two-bowl sink go all the way down to a main drain pipe in the slab, without first joining together in a common y-connector?
I don't remember there being two p-traps under the sink, either. I am certain my memory is flawed somehow... maybe if this is a common setup, somebody can clue me in.
I can't believe I didn't take photos
P.S. The skew of the pipes in the photo, relative to the cabinet carcass, is a result of the original sink having been installed at a 45-degree angle on a pre-existing cabinet peninsula, while the current sink sits square in a new cabinet island)
