Casey Kidwell
Hi there. I've got a solid clog I cannot deal with. Every other drain is fine except for the kitchen. Two sink drain. I started with clogging one side and plunging. Then switched. Pulled the trap and all clean. Uh-oh. My Wife seems to remember a recent episode where she poured a considerable amount of rice down the disposal. Which is what I found using a drain auger. Small "cores" of mostly firm rice, a little paper and coffee grounds. The drain makes a direct right down the wall and there is an overflow/cleanout thingy at 3 feetish. Here's the weird thing. I was reaming from the kitchen side and had a twist of baling wire on the end to try to snag more junk, which I promptly lost in the clog. Well I pulled it through when going from the other side at the cleanout/overflow! WTH? And if I didn't know any better I would say I'm pulling the clog around in the drain. It just feels kind of spongy and the distance I find it at changes. Any help appreciated.
