arcticfox83
Its hard to trust strangers, even harder to trust the previous homeowner, but I try.
Its great to be on the DIY forum, this is my first post. I really need advice. I have a 30-70 year old concrete lateral sewer line that backs up due to root infiltration every 6 months . I have had more jetting and camera footage of this thing than Jenna Jameson since I bought my house a few years ago. This lateral has a clean out 2 feet on the side of the house that runs 60 feet straight out to the middle of the street where at a depth of 56 in it drops into a ten foot vertical riser into the main. The riser is brand new and was replaced by the city. After 45 feet of run from the cleanout, at the curb, the last 15 feet are in the street. I have had quotes from 6k-12k for open trench, bursting and lining (some to the curb, others all the way to the riser). I would LOVE to have someone else dig this up; I dont have that kind of money so the tarot card reader had a vision of a shovel in my future. Its this or kids playing in poop and my wife gnawing my ear off every single day. I want to do this right and have done more reading about this then Ive ever wanted too. I plan on replacing the 4 in concrete with 4 in SDR35 in the yard and evaluating from the yard to the riser in the street (poss. Liner?) when I dig to the 4>6in transition before the curb. It is currently a slowly draining backed up line.
No underground utilities are anywhere near where I am working as confirmed by locate. The existing lateral pipe is 4 in concrete that transitions to 6 in right before the sidewalk in my yard. Thats where I plan on stopping and digging no further. The depth is most likely (two numbers from two different jetting/camera sessions, newest number is shallower depth hmm) 42-49 inches at this transition so I should not HAVE to use shoring (OSHA 5> feet & not in right of way= no required shoring..Anyone??). I have already excavated a narrow 12in wide pilot trench 20 feet from the cleanout so far and am stopping right above the concrete pipe for depth. The path of the pipe excavated so far confirms the accuracy of a black line spray painted over a copper wire I tied taught around the cleanout, to the green (SS) locate arrow tip in the middle of the street above the risers asphalt patch. This line also coincidentally runs right over a large crack in the sidewalk. This is where I am now.
I plan on excavating 18 in wide and 6 in below the concrete pipe. I especially need advice when I hit the 4 in to 6 inch transition right before the sidewalk in my yard. With my numerous home movies of the sewer, the majority of the root infiltration is in the middle of my yard near a juniper bush and tree that I have spent the previous week cutting down stump digging. There is also some minor root infiltration (10% of pipe pre-jetting) 5 feet in from the curb in the street. The condition of the concrete pipe under the street is relatively good. If when I get to this 4>6 inch transition, if it is not backed up at this location, I am considering advancing by hand 4 inch SDR35 into the old 6 inch concrete pipe in my yard to the 90 degree PVC riser in the middle of the street. Should this be beveled? It is a straight line shot. I would advance carefully by hand or wood block and rubber mallet. I am considering renting a camera to place just inside the lip of the new PVC pipe that I would use for real-time guidance as I carefully advanced to the risers top 90 coupling or I can stop 5 or so feet short? The medical world uses the EXACT same technology. I would use a 4 in PVC>6 in Concrete FERNCO adapter seal the connection at the sidewalk to prevent infiltration. This way I would have brand new PVC from the cleanout to the new street riser. Apparently, according to the city, I own the lateral all the way to the citys riser in the middle of the street. They will not fix it and have stated its my responsibility.
I have a rotary laser level in my garage, courtesy of tool time. I will grade with this using start and end depth with freshly placed sand under bedding. Local code only dictates that slope must be greater than 2% (I will be greater than 1/4in a foot). I will underbed with 6 in sand (anyone?) and over bed with 12 in pea gravel. This will be compacted by hand with an 8in square plate compactor (already in garage). Every 6 in of native backfill with be hand compacted and I will add 4 inches above grade for future settling.
Any thought comments and constructive suggestions are greatly appreciated. Please.
